oscillating tool
- Has thanked: 16 times
Does anybody oscillate your tools? We have a Northwood Fabcenter, and I found out on there website that they do not recommend that you do it. I am more curious if it actually have had success and longer life out of your tooling.
Last edited by RILEY@PETERSONS on Fri Jan 30, 2015 1:58 pm, edited 1 time in total.
Getting the Job done right the first time.
Re: oscillating tool
We oscillate flat edges, A, T, Z. +/-1mm. We have been doing 2 passes to overlap -- you can get oscillating lines too.
It is a bit of a science, we run Park equipment and they have a program that handles this for us.
Before, we paused after the metals and quick ran a 400 grit polisher on the edges. It worked but, it was a pain.
We have a set of 8cm z's we oscillate because we use it for several different z profiles.
We also oscillate our 40mm z wheel we run for sizing after laser.
I have had very good luck using ADI's MFP5 oscillating to reduce linear lines. You need to keep your tools dressed and maintained for best results. You want therm to take off as little as possible.
Meow.
Great post about maintaining tools. It's definitely key.Jqualey4130 wrote:I have had very good luck using ADI's MFP5 oscillating to reduce linear lines. You need to keep your tools dressed and maintained for best results. You want therm to take off as little as possible.
