Rodding Tips
- Been thanked: 25 times
I use fiberglass rodding on all sink cutouts. It takes forever and a lot of force to cut the channel in the back side of the stone. It's the hardest part of fabrication for me. I use a Makita skill saw on a track. I've tried rodding blades without much improvement but what I've been using lately is 2 - 8" turbo blades stacked and dress the blades after every pass. it takes me half an hour to do one counter with multiple passes. I know rodding is not used by a lot of fabricators but I feel more confident using it.
Terry Roberts
Fabricator SFA
Lincoln CA 95648
916-595-3324
Fabricator SFA
Lincoln CA 95648
916-595-3324
Re: Rodding Tips
First run a regular turbo blade through, then do the rodding blade. You will see a Huge and when I say Huge I mean really Huge (LOL, could not resist). Difference. It will cut faster and the blade will last longer. This also applies to T-31 anchor bits
Re: Rodding Tips
Terry:
All shop operations have to be evaluated for cost effectiveness. You are investing a half an hour and materials in lowering your risk for breaking tops. For the sake of figuring, let's say each top costs you $50.00 to rod. Let's say you invest $660.00 in two of the 8' Omni Sink Hole Savers and stop rodding. As soon as you pass 13.2 hours/materials, you've paid for the OSHS and now they are paying you. With the exception of particularly delicate stones and/or configurations, rodding is old school and obsolete. Cabinets provide all the needed strength in tension stone doesn't have when properly installed.
Re: Rodding Tips
Brian Briggs wrote:First run a regular turbo blade through, then do the rodding blade. You will see a Huge and when I say Huge I mean really Huge (LOL, could not resist). Difference. It will cut faster and the blade will last longer. This also applies to T-31 anchor bits
That is a great tip. I never thought of doing that for T-31 bits too.
Hi Terry, I just noticed you are practically in our back yard. Give me a call if you have any questions.
Re: Rodding Tips
That's a great tip. I'll try that. Thanks
Terry Roberts
Fabricator SFA
Lincoln CA 95648
916-595-3324
Fabricator SFA
Lincoln CA 95648
916-595-3324
- BReynolds
- Has thanked: 10 times
Re: Rodding Tips
alpha air saw with two blades stacked together, we only cut about a 1/4" wide channel. Takes maybe 3 min to cut both slots and that is with measuring out and drawing a line on the top to follow. You will need ALOT of air to run this saw though and a 3/8" dedicated air line run to it.
Brandon Reynolds
Operations Manager
Legacy Natural Stone Surfaces
Findlay OH
419 420 7440
BReynolds@LegacyNSS.com
www.legacynss.com/
Operations Manager
Findlay OH
419 420 7440
www.legacynss.com/
Re: Rodding Tips
These blades are basically exactly what Brandon is talking about but already welded together with a gap for slurry and stone removal. They are available in 4" and 5" sizes...
https://www.wehausa.com/Granite-Rodding ... /50289.htm
Re: Rodding Tips
Very valid point, and may work for some. But by not means is rodding obsolete. Sink savers are great don't get me wrong, but they do not work in every situation. They can not be in place at all times either. You can't work the edge of a stone with a sink saver on. How many should I buy? 100? That would be a very LARGE investment. Its rare that I'm slow enough to be working on only a couple tops at a time. Perfectly installed cabinets only exist in a perfect world. Even cabinets that are properly installed can/will settle over time and put the stone at risk.Kowboy wrote:Terry:
- crobb
- Has thanked: 129 times
- Been thanked: 33 times
Re: Rodding Tips
This! We've tried many different ways and this is by far the cheaper, fastest and easiest way to rod. We have used both the new Alpha PSC-150 pneumatic skill-saw, which does use an absolutely ludicrous amount of air, as well as the Alpha AWS-125 Electric 5" skill-saw. Both yield amazing results when running two inexpensive 5" blades stacked. We can have a piece with two sink cut-outs rodded in well under 5 minutes.BReynolds wrote:alpha air saw with two blades stacked together, we only cut about a 1/4" wide channel. Takes maybe 3 min to cut both slots and that is with measuring out and drawing a line on the top to follow. You will need ALOT of air to run this saw though and a 3/8" dedicated airline run to it.
Our experienced guys just mark out the length of their cuts but we have made some guides from 2cm quartz for the newbies to clamp to the piece.
- STACKED-BLADES.JPG (500.18KiB)Viewed 348 times
