Hello,
Im at the point now where im going to install a water filtration system in my shop for several reasons im thinking of the simplest ways the shop produces around 1500 sq. ft a week I have 2 rail saws running on water and 1 router can you guys help by showing me pictures of your systems or ideas I was thinking of 2-3000 gallon tanks one taller than the other the sludge water goes in the taller one and the sludge settles to the bottom and the cleaner water simply runs through a 2 inch pipe at the top into the lower tank and putting a suction pump in the lower one and simply shooting it back into the rail saws what's you guys thoughts?
Water Filtration in Shop
- Scooter
Michael Baxter
Re: Water Filtration in Shop
Cosco lined up a row of several 55 gallon plastic drums with one feeding into the next. As the lead drum filled he would replace it. I forget how many drums he used but by the end drum the water was clear.
Terry Roberts
Fabricator SFA
Lincoln CA 95648
916-595-3324
Fabricator SFA
Lincoln CA 95648
916-595-3324
- Has thanked: 35 times
It must have been a few, as we have 4 and the water is still really milky.
Alex L
Workshop Manager for a small NZ based Benchtop company.
The flow amount determines how many barrals one needs. This is my understanding of the subject.
- Been thanked: 70 times
If I remember correctly they out pool filter sand in some of the first barrels.
Chris Graham
SugarGroveMarble
5738 Sugar Grove Rd
Bowling Green Ky 42101
270-846-3711
www.sugargrovemarble.com
SugarGroveMarble
5738 Sugar Grove Rd
270-846-3711
- Has thanked: 25 times
Hey Scooter,
Do you have any additional equipment besides your two 2 rail saws and 1 router? Or will you be adding any equipment in the near future?
As you may know we specialize in Water Recycling Systems in the stone industry - and we would be happy to help you
. Our Systems are designed for the entire fabrication shop; not per machine. We tailor every System to provide you with BOTH crystal clear & gray water; our clear water is filtered down to 2 micro, and is good enough for CNC spindles or hand tools, and our gray water is filtered down to 25 micron for equipment such as you rail saws.
And, our systems are designed to manage ALL your solids on a daily basis - so this means you’ll never have to empty a bucket, or shovel or pump a pit! Plus, we can virtually eliminate your monthly water bill since our systems are a closed-looped design.
I’ll post some pictures below to give you a better idea of what we do - we have over 700 Systems installed across the US and Canada.
When you get a chance give us a call at (603)758-1900 or you can shoot me an email at Jbolduc@watertreatmentonline.com
Scooter, here are a few Systems we have installed. And as I mentioned above, we tailor each of our systems for the particular operation - primarily based on water demands and fabrication volume. So, two photos were designed for smaller operations producing a few kitchens a week, and the other two were designed for much larger operations.
Feel free to call us at (603)758-1900 or you can shoot me an email at Jbolduc@watertreatmentonline.com
- SemiAuto Model 25
- SemiAuto Model 25..jpg (329.18KiB)Viewed 487 times
- SemiAuto - Model 6-10
- SemiAuto - Model 6-10..jpg (178.95KiB)Viewed 487 times
- Model 2-6
- Model 2-6.jpg (284.08KiB)Viewed 487 times
- Model 1-2
- Model 1-2.jpg (335KiB)Viewed 487 times
- Scooter
This is what's in my buddies shop
- tank#2.jpg (301.11KiB)Viewed 481 times
- tank#1.jpg (369.19KiB)Viewed 481 times
Michael Baxter
Add More barrels. Install water socks or cloth filters that you clean out daily. Coco must have had around dozen barrels in a row. The systems shown in the pictures have been replicated to some degree by SFA shops. Do a search and you'll find them. Don't want to take anything away from buying a new filtration system.
Terry Roberts
Fabricator SFA
Lincoln CA 95648
916-595-3324
Fabricator SFA
Lincoln CA 95648
916-595-3324
