http://speeddrawctop.com/
If so, any thoughts/insight?
-Thanks.
steven nenzel wrote: ↑Tue Jul 03, 2018 3:00 pmJust had a demo yesterday. It will save sometime cleaning up files, labeling parts and printing tickets, etc. You have to have the right set up for the gcode function to work... You need a sawjet and a Park CNC. If you have a Northwood milling machine it will not work. If you are using a cnc saw your parts off the saw are not clean enough (ie, radius corners, sink cut-outs etc) for the gcode function to work (this is my limited understanding).
I've been quoted at $400 per month. You will also need auto cad on your computer which is about $1,400/yr.
There is certainly value in this if you are producing a certain volume and have the kind of equipment that can take advantage of it.
