air/water hose reel
I am looking for a air/water hose reel to purchase. I have seen a few of these at different shops but I am not sure who makes them and have not found anyone who sells them. Could someone point me in the right direction. TIA
Re: air/water hose reel
Harbor Freight
- Orijin Stone
We use two separate reels. One for water and one for air. Then we put 2 different types of fittings on (red)(Blue) so the guys don't mix them up.
www.Coxreels.com # EZ-SHWT-150
Steve Z.
Finger Lakes Countertop LLc
Geneva NY
Geneva NY
I set up my old shop with them many years ago. I can't remember if eBay or Amazon was cheaper:
https://www.amazon.com/Oxygen-Acetylene ... B000LQH5CY
Just cut off the welding fittings and install with normal 1/4" hose barb ends.
They are OK to run polishers with the 1/4" hose (both sides), but if you have larger air tools you should have dedicated 3/8" or 1/2" lines for those.
I may be wrong. But... I believe the acetylene hose has a reverse thread. What are people doing to get past this road block? I hate hose clamps. Would prefer not to use them. Any advice on fittings? I love the idea of the retractable hose reel with both air and water.
Mike Blankert
Rocky Mountain Stone Supply
I cut off the ends and crimp with the appropriate barbs...line, fitting, strait to polisher.
Fern
Presidio Tile & Stone
Central Coast CA
805-310-2177
Central Coast CA
805-310-2177
We cut off the ends and use barb fittings, then we use 1/8" quick disconnect fittings to connect the hoses to the polishers. That way the finishers can quickly disconnect the air line from the polisher to blow off their tops they are working on.
Mike Spencer
Blasius Inc
Vassar, Michigan
Blasius Inc
Vassar, Michigan
