2D/3D splashbacks incorrect measurements
I’m having issues with splashbacks templating, every time measurements are too loon from 2mm to 5mm, even if I templating flat surfaces like kitchen worktops, measurements are often 1-2mm too long than in fact. I own 1 year old 2D/3D, always update the software, all procedures carry out as recommended. If anyone could help me I would be grateful...
Re: 2D/3D splashbacks incorrect measurements
Sorry that you're having some issues with your system and would like to help you get it resolved. Email me your contact information and company to dpeter@laserproductsus.com and I will have our tech support team reach out to you!
Dan Peter
Marketing Manager - LPI
laserproductsus.com
"The problem with stealing quotes off the Internet is you never know if they are genuine."
– Abraham Lincoln
laserproductsus.com
– Abraham Lincoln
- crobb
- Has thanked: 129 times
- Been thanked: 33 times
Are the backsplashes already longer in the DXF file or after cutting? When are you noticing the variance?
Yes they are longer in the dxf, even during templating flat surfaces such as countertops and window sill they are usually 2-3mm longer.
- BrianStoiber
Have you reached out to Dan Peter or our support team so that we can address the issue and get it fixed for you? If not, please call 630-679-1300. Press 1 for support and we can help you out. Conversely, like Dan mentioned, if you email me your contact information (phone number and company name) I will have one of our team reach out to you directly.
Brian Stoiber
Director of IT
Laser Products Industries
http://laserproductsus.com | 630-679-1300
Director of IT
I’ve already emailed to Dan
BrianStoiber wrote: ↑Tue Jun 23, 2020 5:41 amHave you reached out to Dan Peter or our support team so that we can address the issue and get it fixed for you? If not, please call 630-679-1300. Press 1 for support and we can help you out. Conversely, like Dan mentioned, if you email me your contact information (phone number and company name) I will have one of our team reach out to you directly.
- Been thanked: 41 times
Mati,
If you figure out how to correct this please let us know! My templater complains of the same thing-when he measures walls(full height backsplash) with our 2D3D all of his dimensions get stretched a bit. To correct this he takes alot of measurements by hand also and manually adjusts the digital files. Big PITA! We dont do alot of full height splash so it doesnt come up often.
Colin O'Meara
Precision Countertops
Spooner WI
715 635 3470
"If I were ignorant I would be happy, but that is not a happiness I desire"-Voltaire
Spooner WI
715 635 3470
- BrianStoiber
Colin, please call into our support department (630-679-1300 option 1) and we can help.
Brian Stoiber
Director of IT
Director of IT
That’s exactly what I always do templating splashbacks, if you find out what they recommend to do to get correct measurements, please explain us on forum
colin wrote: ↑Tue Jun 23, 2020 5:22 pmMati,
Mati38171 wrote: ↑Fri Jun 19, 2020 12:04 pmI’m having issues with splashbacks templating, every time measurements are too loon from 2mm to 5mm, even if I templating flat surfaces like kitchen worktops, measurements are often 1-2mm too long than in fact. I own 1 year old 2D/3D, always update the software, all procedures carry out as recommended. If anyone could help me I would be grateful...
Are you using the non reflective tape LPI recommends? What I would guess is happening is you're shooting into whatever material the cabinet is made of i.e. mdf cabinetry.
As far as your horizontal applications go, are you using the t targets LPI sells? Have you checked to make sure they are perfectly square? If they aren't square your measurement can grow. However, you may be stressing too much over 1-2 mm. Just my opinion.
I use the tape LPI recommends on every surface that isn't painted a light color. My motto is when in doubt, tape it out. I hope this helps! Best wishes. DM if you have any more questions. I'm happy to help if I can.
Edit: My reasoning behind this is you're saying your measurements are too long. The reasonable explanation is you're either shooting into the material or your targets aren't set properly. If it was too short that's a different problem.
