Chiselled Soaptone
A customer has asked me to do a 6cm Chiselled Soapstone job, is this possible?
Mike Law
Kirkpatrick Stoneworks Ltd.
Fonthill, ON, Canada
Re: Chiselled Soaptone
This is the granite business, there are no problems , only expenses.
I did a 6 cm chiseled limestone job, and it would not chisel with our beaver, but it was possible !! just had to chisel it by hand.Anything is possible with the proper tools, either new or old. Whatever works to get the job done. :D
My guess is that that soapstone will not shear as rough as granite, and to use hand chisels, s/b and other methods to accomplish, as Joe suggested. Check out Trow & Holden for hand chisels, I would suggest a 9 point , a hand set, a ripper and a flat chisel, along with one of their Dallet air hammers.
I was thinking od doing it by hand anyhow since my beaver is only small.
Mike Law
I think the real question should be “can you chisel soapstone”?
Although we have not tried soapstone, softer materials usually have a tendency to crush rather than “snap” like most granite or some marbles.
Mark Blanda
Stone Interiors,
Loxley, AL.
Mark Blanda
Stone Interiors,
Loxley, AL.
mikelaw wrote:I was thinking od doing it by hand anyhow since my beaver is only small.
- Trask Bergerson
We've done a number of 3cm soapstone jobs with no issues..it does break a bit different..more of a "dent & pop" but for the most part it has been very predictable to chisel. I assume 6cm would work with the big Beaver..Never wanted to try
I just did my first 6 cm chiseled edge and had alot of fun doing it. It was just a small sill for a friend but you'll get the idea. I did it by hand and found when I chiseled it from the top it did not go all the way through. I flipped it and did it from the bottom and turned out sweet. I took some of my brushes to clean everything up. I also brushed the top. I didn't think it was hard. It turned out like this. . .
Joshua Schaefer
Creative Soapstone
Punta Gorda, Florida
http://www.creativesoapstone.com
http://www.coldstones.net
joshua@creativesoapstone.com
Office: 941.979.9480
Creative Soapstone
Joshua,
That looks great. When we pitch out memorials we always pitch from top and bottom to get that nice "mountain range look" running through the center of the pitching. The idea is to take off enough o leave some decent relief from each direction, then you actually have to pitch less stone off to get a nice look.
Your job looks as if you have been pitching stone for 30 years, very nice.
Nice work Josh,
We like hand pitching as well. Looks better IMO, less machined.
Todd Luster wrote:mikelaw wrote:I was thinking od doing it by hand anyhow since my beaver is only small.![]()
be glad this is in the general forum.
I was LMAO for a whole minute....
Israel Leonor
Field Supervisor
Houston, TX
I won't take you for granite.
Field Supervisor
Houston, TX
- Mike Stites
Very nice Josh, now I will have to make a sample for our showroom.
Mike Stites
5276 S. Saginaw Rd.
Flint, MI
(810)-743-1800
mikestites@gcsm.com
Quality in stone since 1954
5276 S. Saginaw Rd.
Flint, MI
(810)-743-1800
mikestites@gcsm.com
So Big Dan,
Are you the pitcher or the catcher?
Seriously Joshua nice work bro!
The chiseled edge looks great! I am attaching a picture of a 6cm Chiseled edge Soapstone island. We have found that even within Soapstone, different varieties chisel differently. Some varieties lend themselves more to chiseling than others, so we always do a small sample first just to see how it will look.[img]
You can see more pictures on our blog...http://teresinasoapstone.com/2011/01/fi ... in-coloma/
[/img]You can see more pictures on our blog...http://teresinasoapstone.com/2011/01/fi ... in-coloma/
We did a job with the 6cm Jaws and it came out sweet. Not sure if my guys pre-scored it or not (I was away when the jobwas fabbed). The soapstone we used did not have much of the deep veining though. We also had no issues with 6cm Jerusalem Limestone.
- Has thanked: 28 times
I just did a 3cm chisled soapstone job 2 days ago with the Pit Bull from Gran Quartz. It was a piece of cake. I just took my time with the foot pedal as not to crack too hard too fast. It went thru it like a hot knife thru butter with no issues. That Pit Bull is the bomb!
Thanks for the reminder. I was all over that one... I'l just settle for a "Thats what she said" to keep it clean.Todd Luster wrote:mikelaw wrote:I was thinking od doing it by hand anyhow since my beaver is only small.![]()
