You yourself cannot cut this accurate, and I cannot either....Nobody can. You have to run a super z all the way around, no matter how you index your parts........This is not the case with a digitally cut part.This is ridiculous logic because if you are not cutting shite out on the saw CORRECTLY whether you have a hand router, a CNC, an edge machine or a nuclear fission router your jobs will be incorrect off the bat. If your saw or saw guy cannot cutout 36 1/8 X 75 5/8 or whatever the sizes that are given to them then you have a bigger problem than pin stops or laser .
Anybody who runs 2mm overmaterial only on profiled edges and almost never misses raise their hand
I don't think you are getting it nick. Take this everyday situation....Take a 45 degree 16" high bar. The part is 4 feet long on the short side and 7 on the long side.(common situation)....cut it on your bridge saw with 2mm overmaterial. Put it on your pin stops....If your tools don't miss half the time, you are a better man then me. This is because, the angle involved magnifies any error in the cut. Most like you are going to place the long side against 2 pin stops and the end of the long side on the other. If the angle that was cut is not perfect and the width, you will wind up missing with this little amount of OM.
In fact, I have both laser and stops....If I were to set this up on stops I would have to use my laser to check the inherent error in placing the part against the stop.....Now the answer to this problem and I am sure most of you are doing is simply cut 1/8 or more oversize and run a super z.....And really unless you are digitally cutting, it is a necessity anyway, nobody can cut that accurate.....
The point I am trying to make is that your laser can be very accurate and you pretty much don't have to have pin stops, but it cant be unless it is mounted near the center of the table and you have and you have a precut piece to determine the error. It overcomes any error that the sawman would have made and you don't have to run so much OM.
Would someone please try this and post the results....Just put a scrap in the corner of your table on a couple of pods and leave it there all day.......
Chris.....re the thickness issue, it is true, but not too big a deal if your laser is on center. It takes a pretty big thickness difference to throw it off much. Not sure how your laser works, but on mine you can input the slab thickness. If you ask me the water on the part plays more havoc then the thickness, but I guess you don't have that problem anyway as you are not cutting on the machine(parts are dry from the saw)...
Try it man, you will not believe how accurate your laser will become.....Give me the benefit of the doubt.....You know me by now....
