In speaking with James from Tenax this afternoon, he mentioned that the mixing ratio on this product has a plus or minus of 1% . When Filippo suggests using the pre-measured dispensers, it is most likely for that very reason.
For you lamination kings and queens, they've got a new epoxy in a container approaching shallow waters very soon. Marcello and his staff have been very busy .
yes with GLAXS you need to be precise...that is why we create the packaging ... or that's why you need a digital scale.
as far as the new glue is called STRONGEDGE.
I will post more info on tenax guardian sponsor room right now.
Filippo Emanuel
Gen Mgr
TENAX USA LLC
t: 7045831173
f.emanuel@tenaxusa.com
http://www.tenaxusa.com
http://tenaxusa.wordpress.com/
Here is a scale that has a capacity of 3 KG (6.6 pounds) and a precision of 1 gram. It also has a really good warranty.
For anyone placing an order of $300 or more I will get it to you with your order! http://www.digitalscalesaz.com/MyWeigh- ... ital-Scale
www.defusco.com
Stone tools for the professional with the best service & technical support in the industry!
PolyTenax, GLAXS, Touchstone are best choices for laminating but GLAXS is superior from all of them. The result of GLAXS is better then Crystal/Thassos. A scale is best tool for mixing epoxies. The square measurements comes first before installing anything on the marble.
How much time available to work glaxs before
It goes off? I was under the impression it was just a few minutes.
Seems like that would put you under pressure getting all your clamps on.
With Glaxs you have about 15 minutes of working time and 32 - 35 minutes until full cure is reached. This is according to Tenax.
We stock it if you need it.
Mark
www.defusco.com
I always care before implementing anything for Marble. I suggest some remarkable solutions for laminating marble. PolyTenax, GLAXS, Thassos, Crystal are best for laminating marble. You can choose that you feels best & affordable within your budget range.
