Hey Stonies,
I think this Quartzite is crap and I'm not surprised this is happening. Dark spots that look like water absorption around the vanity. Does anyone have a suggestion on why this is happening and a good solution to remove?
I figured I'd use some plastic wrap and poultice powder.
Photo is in the attachments.
Thanks in advance.
Quartzite Staining FUN
- Quartzite stain
- Quartzite1.png (798.94KiB)Viewed 626 times
Michael Ganassa
R. Ganassa Tile Co
dba Washington Marble & Granite
301 831 1329
www.Washingtonmarble.com
R. Ganassa Tile Co
301 831 1329
Re: Quartzite Staining FUN
I'd try heat first.
We had the same problem. So my guy in brazil is saying this:
The quartzite, not just this one but other like casablana quartzite, absorb a lot of water when your cutting and polishing. When you polish the the edge it's trapping the water inside. It will eventually evaporate, sometimes weeks. he suggested to heat it. but be carefully not to heat it to hot, it will crack.
Vincenzo Marano
Arika Granite
Arika Granite
Vincenzo Marano
Arika Granite
Arika Granite
- gssfabrication
- Has thanked: 34 times
- Been thanked: 21 times
You might suggest opening the cabinet door below and ideally have a fan blowing air inside the cabinet to help circulate the moisture that is finally making its way out. If you sealed the top and the sides, easiest place for water to escape is the unsealed underside presuming its not thick coated in epoxy with mesh.
Good luck.
Rick Graff.
